Air powered venturi vacuum pumps
This article is from here
http://www.aircondition.com/tech/questions/38/
Ambient temperature is important when you try to use one of them.
If we wish to lower the boiling point of liquid, we simply remove the pressure that's on top of that liquid. That's how we boil water out of an air conditioning system. We use a vacuum pump to bring the system to a level of near perfect vacuum so the water will boil off and be carried away as a vapor. It's important to note that ambient temperature has much to do with the point at which liquids will boil under vacuum. The greater the temperature, the fewer microns of vacuum will be required to start the boiling process. If you've been keeping note, you know that non condensables (air) and moisture are two things you definately don't want in your a/c system.
The chart below shows how temperature plays a role in the level of vacuum needed to boil water.
<table style="page-break-before: always;" border="1" bordercolor="#000080" cellpadding="0" cellspacing="0" width="534"> <colgroup> <col width="273"> <col width="259"> </colgroup><tbody> <tr valign="top"> <td sdnum="1033;1033;@" bgcolor="#0099ff" width="273">
Inches of Mercury
</td> <td sdnum="1033;1033;@" bgcolor="#0099ff" width="259">
Boiling Point of Water °F
</td></tr> <tr valign="top"> <td sdnum="1033;1033;@" bgcolor="#99ccff" width="273">
26.45
</td> <td bgcolor="#99ccff" width="259">
120
27.32
110
27.99
100
28.50
90
28.89
80
29.18
70
29.40
60
29.66
50
29.71
40
29.76
30
29.82
20
29.86
10
</td></tr></tbody></table>
All values are at sea level. Subtract 1 inch for each 1000 ft. above sea level
Venturi pumps are popular with the do-it-yourself mechanic since cost is often times the biggest factor. I'll give these little pumps some credit since they can remove a substantial amount of air from the system, provided you have an air-
compressor with enough rated CFM to operate the venturi pump long enough to reach the desired vacuum level. If air capacity to the pump tapers off, so will the vacuum level. Typical requirements for a venturi pump is <!--StartFragment --> around 4.5 CFM at 90 PSI.
We used a large commercial compressor dialed in at over 150 PSI. with our air vac, and we were able to maintain the suggested air requirements. The vacuum produced didn't even register on our
Yellow Jacket micron gauge. That's something most electric vacuum pumps can achive in very short order.
Regardless of what sales literature may claim, we believe, under most conditions, you won't be able to boil much water with the vacuum level produced with a venturi pump. Therefore, we feel that air powered a/c vacuum pumps have no place in an automotive service shop. That is, unless you plan on hacking the thing apart to make some other cool air powered vacuum device. We have several useful items in the shop that derive their power from the guts of a ventui pump.
If you plan on servicing A/C systems, and want professional results, invest in a good electric vacuum pump. It's not uncommon to get ten or more years of service from a good electric pump. That's a good return on investment. As an option for the do-it-yourself mechanic, some tool rental companies now rent electric vacuum pumps on a daily or hourly basis. I think that would be better than overworking your air compressor for an hour or more, just to get mediocre results.
