Keep in mind your small block 1967 engine stands are the same as 67-70 FE stands and are often worth more than the set you seek. You should offer to swap someone straight across for their 68-70 small block frame stands and the both of you will walk away with a big smile as all you will be out is about $12 in USPS flat rate postage.
