Ever since I got the car 2 years ago I've had problems with the sequentials. When I first got the car they sometimes worked. But last spring the original sequential motor jammed, so I decided to upgrade to the solid state main turn signal unit. After replacing this they wouldn't sequence, but the middle light on both sides would flash. So after some research I found that a bad emergency flasher relay was most likely the problem. So I ordered the new repro k-10 emergency relay, and after installing this, they still don't work. Only the middle lights will flash. My dad who installed it is an electrician so I'm 99% sure it's hooked up correctly. I don't know where to look now. Any ideas???
Thanks, Nate B
Thanks, Nate B
