Ever since I got the car 2 years ago I've had problems with the sequentials. When I first got the car they sometimes worked. But last spring the original sequential motor jammed, so I decided to upgrade to the solid state main turn signal unit. After replacing this they wouldn't sequence, but the middle light on both sides would flash. So after some research I found that a bad emergency flasher relay was most likely the problem. So I ordered the new repro k-10 emergency relay, and after installing this, they still don't work. Only the middle lights will flash. My dad who installed it is an electrician so I'm 99% sure it's hooked up correctly. I don't know where to look now. Any ideas???
Thanks, Nate B
Nate -
Both the original and the electronic system require 12V on the light blue wire
of the relay connector. Use a test light to verify that this wire has power.
The complete electronic system unit has a single 1/4" quick disconnect male
pin that must be plugged into the receptacle with the light blue wire. The old
emergency relay is not used with the complete system.
Vic Yarberry
Cougars Unlimited
www.cougarsunlimited.net
