Just want to give folks a heads up, if you want to change your manual drum brakes to power and not change the brake pedal then use the Scott Drake power brake booster. Install took about 4 hours (its a pia to bolt up) including re-bending master cylinder brake lines and bleeding brakes. Booster does not look like the factory but it sure made the car easier to stop.
