I have some rust spots under the vinyl top. i am going to use por-15 to seal it. There is also rust around inside sail panel areas from back window leaking. I am going to put a new window seal in and fix rust around it.
The question is, "Should I remove the headliner to seal from the inside as well?" Thanks, Scott
