Yes, that's correct. Seems the Mustang is shaped a bit different at the wheel opening. However, if your Cougar doesn't have rocker mouldings, then you'd never notice the diference. It's just that with the mouldings, the curve is different than the rocker and would have been noticeable.So it sounds like your saying that even if it had been long enough the shape was not right at the rear wheel? Just as well try to fab something rather that cut the rear section from a mustang rocker?
I am sure there is someone that has done that before...but they may be mumbling and counting their toes now. Rockers can be a PITA to fix if it doesn't go right the first time.So has anyone successfully used 67 mustang rockers to repair 67 cougar for the area just in front of the rear wheel?
