1 - 8 of 8 Posts
Hi can someone tell me if this is a rimblow wheel or standard three spoke pic isn't the greatest i was afraid to take off the tape not sure what would happen it's in bad shape i think it's plastic not wood Thanks p.s scary thing is i drove with this for about 3months last summer
sure looks like a rimblow to me. dont know why its all taped up though.... only one way to find out right?? i dont know why it has that center pad on it though.... never seen one like it before.
70 Rim Blow
It's definitely a 1970 Rim Blow steering wheel. It isn't real wood. It's plastic that's grained and stained to look like wood. The center section should also be a wood vinyl insert. If I'm not mistaken, the standard non-XR7 steering wheel was a 2 spoke design.
Tim B
Discussion Starter · #6 ·
Horn switch works if that's the switch you mean, it was unhooked (wire ) i plugged it back in an surprisingly it did work, i was curious about the wheel because the one's i've seen had a round center emblem, the tape i think is holding the plastic/woodgrain on thanks
Rimblow
It looks like a rimblow steering wheel. Looks like the one I have! Mine needs restoring and you can have it done for about $400. You are missing the running cat in the center. Mine has no wood grain look at all. I have a '72 XR-7.
1 - 8 of 8 Posts
