So, just finished installing my first new engine bay panel. Don't have a spot welder, so drilled 3/8" holes where appropriate and puddle welded the new panel in. I then ground down the welds, but would like to finish the surface so I am not seeing the grind marks and little pits from the welds. For this area, what would be best to fill these in? Body filler, filler primer, etc?
Thanks
This is one spot where I put a quick coat of paint on it to see how the welds and grind marks telegraph through... quite a bit.
Thanks
