Looking for recommendations for successful ways to re-attach the headlight grille to the headlight door
The pins holding the grilles to the doors are slowly breaking off
Appreciate your advice
- Is it best to remove all the pins and reattach the grilles?
- what do you do to reattach the grilles?
- would double sided automotive trim tape be sufficient to hold them or should they be screwed?
- what size screws do you use?
- what size hole do you drill in the grille to attach the screws?
- do you use loctite or spring washers to hold the screws
