Mike, does that mean..... If I were to stroke my Cleveland to 'only' a 393; I should NOT immediately go out and get "6.5 Litre" badges? :1poke:
A few caveats:
1. The "393" is itself a misnomer; with the stroker kit actually producing closer to 392 CID. The 'extra" cube is just there to differentiate the engine from the old Mopar Hemi.
2. The "351" nomenclature was similarly 'assigned' for a similar reason! Bore/stroke/"swept area" all are virtually identical to the 352FE; and Ford wanted to 'remove the confusion'.
3. Even at 'only' 392 CID, a stroked Cleveland or Windsor (Almost said "Wheezer" - spend too much time lurking on 351 Cleveland dot net) is closer to 6.5 Litres than a 390FE.
4.) I wouldn't kick any of them out of a car!
There are lots of grey areas involved with Ford engines. If it were a Chevy, you could just thow in the SB or BB (I believe you can a stroker kit to make a 427SB now). If I were to do my Cleveland to 427 (which I wouldn't because it is too much stroke) I would simple call it a 427 Cleveland.
I knew of the 352/351 thing, and understood why they did it. My Clevo is punch .030 over, but I don't go around calling it a 357.
I don't see a problem with putting a 6.5 or 7.0 badge on a car with a stroker (not a fan of non-original badges though), but putting an original style 427SC badge on a car with a stroked Wheezer is iffy in my book. If I see a Cobra with this badge on it at a car show I always walk over to it and look. I have only seen one that actually had an FE in it so far, all other times I was disappointed in a way.
I will no doubt want to stroke mine at some point ( I am a true beliver in Tim Allens outlook on life), but I will call it a 392 or 408 Cleveland or just a Cleveland. To be honest, I would prefer to stroke a "small" block over having a "big" block for a fun vehicle because the torque on a long stroke engine is unreal, while bigger bores with shorter strokes are more for spinning high RPM's and horsepower. If I were going for originality I would use the original engine, but for play, "small" blocks are it.
One thing to point out is that everything I just said is all crap in the bigger picture, just my opinion and what I like. When it comes to my cars, I will follow just that, my opinion. When it comes to anyone elses cars, they should follow their opinion and tell me to stick it where the sun don't shine. I am all for building it the way you like it (this is obvious if you have seen any of my build), so none of this should influence anyone to not do what they plan or like.
If you want a frickin stroked W in a GT-E clone, I say go for it, might be a more fun car to drive than the original anyway. If you want to strip out the original BOSS 2 from a 70 Eliminator and put a W in because you think Clevelands are crap, go for it. I will have many not so nice things to say about that one, but at the end of the day it is your car.
