Can I remove the harmonic balancer center bolt with an 1/2 impact,
after removing radiator,fan,shroud. I have a puller also.
I suspect the balancer has slip and I'm not getting a true reading.
I tried a piston stop tool,my engine even with the plugs out is hard
to turn. Engine 1000 miles since built,
I can see using the tool on a 327 chevy,but the 302 ford is at an angle
and it never felt right trying to use the tool.
So I plan on replacing the balancer with a new one.
Has any one used a summit harmonic balancer #c4269 $145.95 ?
Thanks
Thanks
