What other mods do you have? Is it a factory intake or aftermarket? If aftermarket, is it single or dual plane? If the engine is basically stock you need about 500 cfm, but a well tuned 600 cfm carb can be very versatile. I would look at the Carter AFB style Edelbrock 600 cfm, with a tune kit and tune manual. When running that style of carb, it's best that you run a good paper element fuel filter because the jets are on the floor of the fuel bowls...any debris that makes it past a mesh filter will clog the jets.
