1 - 8 of 8 Posts
Yes .
Well I guess that all depends on whether or not you have a 40 ton press and appropriate fixturing...
Or, perhaps I spoke too soon, how much can you bench? :buck:
If you have the proper tools you can press them on. However, getting them off is the trick. Around here only a few shops know how to do them correctly -- about $25/side
You do NOT need a press! I have one but it is easier to just get a piece of pipe that is just larger than the axle slide it over and use it like a slide hammer. takes about 20 seconds to press the bearing on.
Chris AZ
I saw someone once use a tool kind of like what you're talking about.
Re: Rear wheel bearing?
Chris AZ​
1 - 8 of 8 Posts
