1 - 20 of 39 Posts
My cougar has an open rear end. I would like put a posi rear end or some sort of locker system in it. I was just wondering what would be the best one to go with?
thanx
Probably the easiest and cheapest thing to do would be to install the 9" rear axle assembly from a 69-70 Cougar unless your car is a big block '68 in which case it already has a 9" rear axle.
Either way the Detroit Locker differential is the best one available regardless of price; it also costs less than most units available.
The differential assembly is available from :
http://www.summitracing.com
You can put a locking differential in an 8" rear but it will cost more and be weaker.
actually in all honesty, the 8inch is just as strong as the 9 inch and 100lbs lighter. Alot of the internals in the 8 inch are the same peices used in the 9, like spider gears and side gears. Just check out this article at ford muscle http://66.96.130.106/archives/1999/12/lockright/index.shtml
I greatly appreciate the help, i will probably put a detroit locker into it because of how well known it is and it comes highly recommended.
thanx
I think the 9" is about 15 pounds heavier than the 8". The welded housing assembly is 5 pounds heavier, the center section 10 pounds heavier. If 31 spline axles are used add another 2 pounds. Max difference can be 17 pounds in that case.
I am not aware of any Detroit Lockers made to fit an 8" rear. Where did you find that information?
How difficult would it be to switch out the entire 8 inch open diff pumpkin for an 8inch posi/locker, is that the easiest route to go?
It would be easy but probably cost would be about the same as installing a complete 9" rear.
From reading the article, I believe they are implying the entire rear-end would be 100 pounds lighter. However, I don't see how this could be. I'm with Royce, the center section probably isn't more than 15 or so pounds lighter. As for the housing itself, have you ever lifted a 8 or 9 inch housing, without axles or pumpkin installed? There is nothing to it. And, the axles are common between both setups. 100 lbs, I don't think so...
Having changed many 8" and 9" center sections, I have to agree with 15-20 lb estimate. I don't know where FordMuscle came up with 100 lbs, they are usually very good about such things. :confused:
As far as the power trax posi unit - It installs easy, worst thing is setting up the gears again. This is made a lot easier if you are using the same gears. :)
Discussion Starter #11
So if i do go to a 9" rear end, do i have to change the housing to or can i just swap pumpkins and internals?
You have to swap housing and all.
My father has an AUburn posi in his 8" 66 Mustang and loves it. It is a clutch type. It's doubtful that you would need a 9" with a small block. I would swap to 9" only if you had a complete one at a reasonable price.
Use the link in my earlier post to go to Drive Train Specialists. They list the Auburn for the 8". Around 430 I think. Summit or Jegs may have them as well - I believe I have seen them in Jegs catalogs.
I don't have anything at all to contribute, but it's pretty much impossible for me to NOT look at a thread with a title like this one...
Alas, things are never as they appear, are they ;)
:lol2:
Discussion Starter #18
What vehicles would i find a 9" trak lok or even and 8" for that matter. i know some older fords came with an 8" trak lok.
8" was used in 6 cyl and small block Mustangs and Mustang II through 74 I believe. How many of them were locking? Probably none. I don't think Ford offered a locking 8" from the factory. Locking 9" is no easy find now a days either. For a 9" I would look in pickup trucks.
The 8" rear was used at least until 1978 in the Mustang II, Granada, Mercury Monarch, Maveric and Comet. Posi's were a factory option from 1963 until 1978 in 8 inch rears but they were extremely rare. I have seen a lot of rare and unusual things in all the Cougars, Mustangs, Falcons and Comets I have owned but none had a posi.
1 - 20 of 39 Posts
