With this 351 M code would it still have the 3.00 rear end?
More than likely. Check the tag on one of the bolts that hold the pig in it. The # closest to the hole is the ratio. mm
Thanks Mark,intrested in a 351 Mcode with the tranny?
Unless, for some reason, the rear end was replaced, the code on your door tag will also tell you what ratio it is. For example, if it says 6 where it says trans, that is a 3:00 open rear end. What does it say?
No thanks Dan, next ones going to be a bb and its going to be put together in the next few days. Or that is as soon as my backordered cam gets here. 69Kat, may need it though if its a good runner!
Pats tip on the door plate is good except so many of these old cars have had so much stuff changed over the years so thats why I suggested going right for the rear end tag. If its misssing you know that its been changed and you maynot be able to trust the door tag. mm
Thanks for the Referral Mark! Hey dan, is that 'M" code you have a good runner??? I ftheis engine I'm lloking at today doesn't work out then I might want it....
Discussion Starter · #7 ·
Have to see
Im going to get it started be for I take the wire harness out.Hesaid it did run when it was parked-(they all do) we will see though
