I brought the rear axle assembly home the other day. Still have the springs, tires and yoke on it. I want to start dis-assembly so that I can clean each part and paint it. Do I have to pull the yoke out of the front before I take the cover with the bumper off? Then I can pull the plate on the differential? As far as the axle bearing I guess they are alright? How would i know or should they just be replaced? Rear axles seals? same thing, they are not leaking now but car has basically sat for 20 years so I might not now if they leak or not. As the rear end is off the car seams this would be the time if i was going to replace them huh? I just received my shop manuel for the 1968's Maybe I will find this information in it. I haven't even looked at it yet. What other maintenance could I or should I do to the rear end? thanks
