I am looking for ideas to repair the area where my hood hinges mount to the rear aprons. There is not any rust on the apron; the holes that hold the 'nut-serts' for the hood-hinge are wallowed out. Help me pro/con the options or come out with ideas I haven't come up with yet.
A) Replace entire apron
I do not really like the idea of replacing the entire apron, but will do if needed. Just not like the idea of the implied work of drilling out the fender mounts, all of the spot welds, plus using anymore replacement sheet metal than needed.
B) Section out the mounting area from a new panel
Butt-weld or lap weld in only the 'nut-sert' section. This is the direction I am leaning. I 'think' that a properly done lap weld will be strong enough and only visible from one side (under fender). I understand that there is the risk of rust forming under the lap. But I am not sure a Butt weld will have the needed strength to deal with the stresses of the raising lowering the hood; prove me wrong...
C) Rig up some kind of weld to re-attach the 'nut-serts' to the existing apron. Not digging this option as the holes are pretty ragged out.
The hood opens as if nothing is wrong. But I know this is only going to get worse.
Thanks in advance.
Thanks in advance.
