Here is the story, about 2 months ago I purchased my stepgrandfathers car. 71 cougar, this is as much about it I know: 460 balanced and blueprinted, D0VE-C heads, SCJ 429 intake, SCJ Holley carb (number research says it is OE to a 70 Torino or Cyclone.) has ford exhaust manifolds, fit car, can't read numbers.
Car was not driven for at least 6 years according to the CA tabs. was told it was started and ran regularly until approx. 2 yrs ago. Transported car here, oiled cylinders, turned over by hand, rebuilt carb, and it started up, ran good. engine ran REAL strong. drove approx 30 miles to my home from work to store for the winter.
What I know about the engine is this much beyond listed above. was told is stock 460 block, maybe bored some. heads have been gone threw, to what extent I do not know. has a cam, how big, unknown. crane cam roller rockers, complete jacobs ignition, box, dist., and wires. according to my grandma, approx. 8k was put into the engine with machine work ect.
This is getting to long and I am getting to the point. Was going to remove the engine anyway to detail the engine compartment and fix some hack wiring. removed a valve cover to see what things looked like, and found rusted rocker arms, rusted/pitted rollers on the rockers. do you think I should tear the thing down and check all the bearings/ ect for corrosion damage.
