Picked up my heads and a pushrod length tool. Have '79 Windsor block and '70 heads, with 1.7x roller rockers. Picked up 8.15 hardened pushrods, but realized after the fact that the deck height was slightly higher with the '79 block. After I get the passenger head bolted down, and have the lifters at rest, what should be the contact range of the lifter to the valve tip as I turn the crank? Should it be smack dab in the middle throughout the lift? Thanks, Eric.
P.S. The pushrods the mechanic used back in '90 were the exact same length, albeit with 1.6x standard rockers.
