Upon checkin' out my new ride.....and playing around to make sure everything works, I found out that both rear quarter windows only roll down like an inch or two at the most. Is this a problem with the regulators? Or would a good lube maybe help these out? I want them to work normally. Anybody have this problem or know exactly what it is?
Thanks in advance for help and feedback!
Remove the trim panel and look inside. The tracks are probably dirty. Clean and lubricate. Try that first.
Like cougar1 said... I just went through adjusting the 1/4s and they were hard to roll up and down as well. After lubing the tracks, they worked great!
Mine don't like to roll back up all the way. If the left side goes all the way down it won't roll up at all. I had to take off the panels to get it back up again, but didn't see what the major malfunction was so I just leave em up for now...Think I have a regulator problem?
Banned
quite possibly the regs are bent now seen that a few times. Take em out bang em flat reinstall w/grease and up and down they should go. Catzyalater
Thanks Ray, I'll give it a whirl (that is next time I get up the gumption to pull the panels)...So many projects so little time...
