long story short...we sprayed the car and didnt prime the body filler spots, it bled through...so we sanded those spots down then primed that area...then we shot them spots again with paint...it was a little darker gray primer than the high build primer we used.....
question is what would you do if the spots we resprayed, it still shows a little bit....does the color of primer affect the shade of the paint?
The basecoat was dupoint metallic blue
High build primer was from evercoat
Epoxy primer (we used that to cover up the body filler spots) was from evercoat
The high build primer and epoxy primer was a little different shades of gray...
So far, we have shot the spots with 2 coats....the spots where the darker primer is shows the darker base
any suggestions!?
any suggestions!?
