Sometimes the routing for the hoses is different between the big and small block engine. I had to switch to the big block configuration when adding headers to a small block because the houses were rubbing on the header pipes. Big block lines go straight down from the steering pump, small block run on the inside of the fender, down low. If running a big block I would change out the hoses. They are easier to work with as a bonus.
Charlie
