Yep, not Lin is 100% correct. The pump innards (what goes bad) however, have been the same for just about forever.A true 1970 power steering pump was a one year only. Identified by the offset high pressure fitting on the back. This pump would need to use the all steel pump mounting bracket, instead of the 1967-69 aluminum bracket.
1970 Mercury Cougar / Ford Mustang Power Steering Hydraulic Oil Reservoir D0ZZ-3A697-B - Used
<table width="600"><tbody><tr valign="top"><td width="300"><center><table align="left"><tbody><tr><td align="center"></td></tr><tr><td><center>Click to enlarge</center></td></tr></tbody></table></center></td><td width="300"><table border="2" cellpadding="5"><tbody><tr><td><form id="yfc_1" method="post" action="https://order.store.yahoo.net/yhst-11089400041767/cgi-bin/wg-order?yhst-11089400041767+d0zz-3a697-b">Print This Page
Bookmark Page
Availability:
Usually ships the next business day
Orderable?
Part #: D0ZZ-3A697-B
Price:$25.85![]()
<input name="vwitem" value="d0zz-3a697-b" type="hidden">I Need to Order: <input name="vwquantity" value="1" maxlength="3" size="3" type="text">
<input value="Order Item (add to cart)" type="submit">
<input name=".autodone" value="http://www.cougarpartscatalog.com/d0zz-3a697-b.html" type="hidden"></form></td></tr></tbody></table></td></tr></tbody></table><map name="17d384e42ff464d22"><area shape="rect" coords="0,0,175,131" href="http://ep.yimg.com/ca/I/yhst-11089400041767_2168_202163596"></map>![]()
Description:
D0ZZ-3A697-B Application is 1970 351 engines. Originally found on pumps with tag number HBA-CC. Has the off centered high pressure port.These used cans all have at least one minor ding and are what we call above average condition.
The insides of this one is the same?Yep, not Lin is 100% correct. The pump innards (what goes bad) however, have been the same for just about forever.
Nope,i did not get any information about that ....who do you mean ?So you did not try the stangersite guy I pointed you to? Seems to me he was very reasonable on price and had a lot of options (that could help out a person in your situation/location).
Here you go Chuck, my post with the info on your previous thread regarding the pump.Nope,i did not get any information about that ....who do you mean ?
And what i am considering is just buying a new pump ( keep te original can and pulley )just install a new pump
but since there are a couple of pumps on rockauto i dont know which one i need...
@ Cougar CJ, i tried ordering one from WCCC but the quantity was not available for a new steering pump
here are 3 different ones...
http://www.rockauto.com/catalog/moreinfo.php?pk=1785700
http://www.rockauto.com/catalog/moreinfo.php?pk=1785660 ( with housing )
http://cardone.com/English/club/members/customer/ecat_brands/imageinfo.asp?PARTNUM=20-235
(i cant go for a core unit cause i need one asap )
Greets !
SOrry ,missed that one.Here you go Chuck, my post with the info on your previous thread regarding the pump.
http://www.mercurycougar.net/forums/showthread.php?56854-70-Steering-pump
Have the same question !i used the stangersite guy to rebuild my control valve and he did a good job.
considering do the same thing with the p/s pump. it works ok, but way better at higher rpms. not so much "power" at low rpm. any way to tell if rebuilding the pump would improve the performance significantly?
billy
'70 351W
