Be aware
when ordering a pump from mustangs unlimited that the line from the pump to the cylinder is different from the original. The original you screw it into the back as to a repo you screw the line into to the back of the pump. I know it sounds weird but my power steering pump was making funny noises and i knew it was on its way out so i changed it, and when i seen the difference in the back i had to order a new line. Come to find out the bend in the line was also different then the original. So what did i do? I cut the end off of the original and cut the end off of the repo to get the pressure fitting and flared the end of the original and there ya have it a correct bend w/ a new fitting
thanks
pat
