I have a pair of Don's super dooper sail panels to go in the Eliminator
I figure that since I have them out I could put in some rear courtesy lights. Unfortunately I don't have another set of XR7/decore panels to use as a pattern
Could someone help with the position and dimensions of the hole for the courtesy lights.
I need the following dimensions
A picture would help - particularly if the hole isn't circular
- A - horizontal distance along the lower edge from the lower front corner to the centre of the hole for the lights
- B - vertical distance from the lower edge to the centre of the light cut-out - measured from where the centre line disects the lower edge
- diameter of the cut-out for the lights
