:1zhelp: Hi All, I sure someone out there will have some ideas for me or at least confirm my suspicions. Here's my problem, the steering on my 67 Cat will not return to center after completing a left or right turn( No matter how tight of a turn). I have to recenter the wheel myself, it will not even try to recenter itself. There is no noticible play in the steering, as a matter of fact it feels pretty good. Upper and lower ball joints have been replaced, along with the tire rod ends, center link, control valve, power steering cylinder etc. One thing I have noticed is that I only get about 1 3/4 turns out of the wheel to the left and better than 2 turns to the right. My thinking is that the steering box it's self may not be center and that the shaft bearing may be too tight? I have adjusted the sector shaft (loosened it) but there was no change except to add play in the steering, the wheel would still not even try to return to center, so I adjusted it back to the point it was previously. I just had a new front end alignment when I replaced the power steering cylinder (last week), so I don't think the problem would be excessive caster. Other things I have checked for included, (1) over inflated tires - OK (2) binding in the steering column - Good (3) Lube and Pwr steering fluid levels - OK So this brings me to the point that I mentioned above. Any Ideas?????? Thanks
