1 - 12 of 12 Posts
Sorry about asking this again, someone did send me the correct gap measurement but for the life of me I can't find it. 351 2V 4 brrl holley, isky cam, bored out to 0.20, points, equals what gap?
Dayle, dual diaphragm is.021 inches.Single diaphragm is.017 inches
Bruce
"dual diaphragm is.021 inches.Single diaphragm is.017 inches"
And what do I have, sorry, you have lost me?
Dual diaphragm is 2 vacuum hoses. Single is 1 vacuum hose(sorry!)
Bruce
POINT DWELL: 28 DEG. -- POINT GAP: 0.017"
Okay, one pipe from vacumn advance, which equals 0.017 which equals 0.43, I hope you mean vacumn advance. Does it make any difference if I have a racing cam in, bearing in mind that the btdc changes from 6 to about 11 btdc
No, it shouldn't. The point gap sets the amount of time the coil is saturated. When the points open, the magnetic field collapses and that is what gives you the spark. If you want a lesson on transformer theory, you better hit the library...
"If you want a lesson on transformer theory, you better hit the library..."
Don't be nasty, I can't think when I am under pressure, will realise that it was a dumb question when I re-read my post tomorrow...............:)
I didn't mean to sound nasty, it's just very complicated and if you were interested, you should get a book on it...(sorry again!)
Bruce
I was joking, sorry, and it would be interesting to find out more, its just a case of finding the time................:) :) :) :)
Make sure you set the dwell or points gap which ever way you set them first then set the timing second. The dwell will change you timing.
Radcat
Discussion Starter #12
Thanks guys.
1 - 12 of 12 Posts
