1 - 11 of 11 Posts
I've just received my Octane LED lights:
SET-033-034-G5-LED (2)5-3/4 Crystal Clear Metal Glass Headlight LED 4000Lm H4 Light Bulb Headlamp Set
"Product description
THESE ARE 5.75" CRYSTAL CLEAR GLASS FACED / METAL BACKED HEADLIGHT - SET OF 4 Includes Octane Lighting H4 (9003 / HB2) 40w 6000k 4000 Lumen LED High Intensity Discharge Hi/Low Beam Headlight Light Bulbs with Canbus Error Canceller Plugs! SET OF 4 - 5-3/4" CRYSTAL H4 LED HEADLIGHT KIT CRYSTAL CLEAR GLASS / METAL BACKSIDE HIGH INTENSITY LED BULBS (4) LOW/HIGH BEAM HEADLIGHTS NO MODIFICATIONS NEEDED - PLUG AND PLAY LED HEADLIGHTS PART NUMBER INTERCHANGE: H5006 / H5001 OR 4000 / 5001 DOT SAE APPROVED LED BULB SPECIFICATIONS: Bulb Type: - Generation 5 - H4 (9003) LED Low Beam / High Beam Headlight with Canbus Error Canceller Plugs Canbus Error Free Electrical plugs prevent any headlight error codes Wattage: 40W / EACH PC Luminous Flux: 8000LM / Set ,4000LM / Each Bulb Beam Angle: 360? Placement on Vehicle: Left, Right, Front Color Temperature: 6000K Pure White THIS LISTING IS FOR A NEW SET OF 5 3/4" CRYSTAL CLEAR GLASS LENS - METAL BACK HEADLIGHT BULBS. THIS SET INCLUDES (4) LOW/HIGH BEAM HEADLIGHTS WITH HIGH INTENSITY LED LIGHT BULBS (NO WIRING OR BUCKET MODIFICATION NEEDED). THESE HAVE THE ORIGINAL SHAPED PRONGS ON THE BACK SO THEY WILL PLUG RIGHT INTO YOUR ORIGINAL WIRING HARNESS PLUGS. THESE PLUG AND PLAY LED HEADLIGHTS WILL FIT ANY CAR OR TRUCK THAT HAS 4 ROUND GLASS HEADLIGHTS. WILL FIT INTO STOCK BUCKETS. EACH BULB IS 5 3/4 INCHES IN DIAMETER. THIS H4 LED HEADLIGHT KIT IS GLASS AND WE WILL TAKE EXTRA CARE IN PACKAGING. DOT SAE APPROVED INTERCHANGE: H5006 / H5001 OR 4000 / 5001"
Anyone tried it? A bit nervous to plug it in my cougar 67!
Discussion Starter · #6 ·
Now searching for LEDS FOR SEQUENTIAL backlights: either plasma from WCCC (for now its B.O.), or leds from Dorman.
WCCC has / had new LED Plasma's in stock again. I just added the kit to my 73
Were they really plug and play? Did they fit in the headlight holder?
Good question, I heard some needed to cut and rewire the harness. I don't call that plug and play lol
1 - 11 of 11 Posts
