OK, so I think i have almost everything I need now to convert to front disc brakes on my 68. I have a pair of C8OEA Spindles, booster, pedal, etc....On the "donor" spindles, there are two different styles of backing plate. One is basically flat, the other one has much wider spacing and 'aggressive' looking cooling capacity. Is one just bent up a bit more than the other, or is this a design feature?
P.S., I don't have the bolts that actually hold the calipers to the spindles, has anybody got an extra set, or should I go ahead and post a 'parts wanted' ad?
