1 - 12 of 12 Posts
Ok the hood hinges on my 68 along with the caps on the shock towers were originally phosphate and oil. These were media blasted along with the car. Now how do I go about getting them back phosphate and oil?
Harv,
Most people paint the hinges natural (cast finish) that's what I did. But, you could also buy an Eastwood's blackening kit and brush the solution on until you get a dark finish like the original (the kit makes real phosphate with the acid solution). Then, spray with matte clear to duplicate the oil part (only better).
Thanks, I will check with eastwood.
I painted mine with eastwoods detail gray spray paint after sand blasting and a light sand by hand with fine sand paper...this is how it turned out going the spray paint route...
Have you thought about PPG Metal prep (phosphoric acid) and then oil? Very nice finish.
Don't know anything about the metal prep? will look that way too. Those pictures in detail grey look nice.
Think this might be the same as the Eastwood kit but I seem to recall their acid was not Phosphoric, some other acid. I have the metal prep solution as well, never though of using it to blacken stuff. The Eastwood kit works very well BTW.
Bob when you say blacken? The original hinges were a kinda a golden grey in color not quite bronze but not black?
Yep, that's phosphate and oil. Eastwood calls their kit "blackening" IIRC.
K thanks, need to make up an order for them.
I second the rec for Eastwoods blackening solution. I've used the kit to blacken tons of bolts and they look better than the fresh stuff I get from AMK.
1 - 12 of 12 Posts
