Does anyone have a part# for a phenolic spacer on an Autolite 2100??
I'd like one thin enough to use the original carb studs.
I would think you can find one at your local parts store, if not, then you can always stack gaskets, that works also.
We sell them for the 1968 390-2V.
<table width="600" border="0" cellpadding="0" cellspacing="0"><tbody><tr valign="top"><td width="600">Used 390-2V X - Code Spacer Plate for the 1968 Mercury Cougar / Ford Mustang
<table width="600"><tbody><tr valign="top"><td width="300"><center><table align="left"><tbody><tr><td align="center"></td></tr><tr><td><center>Click to enlarge</center></td></tr></tbody></table></center></td><td width="300"><table border="2" cellpadding="5"><tbody><tr><td><form id="yfc_1" method="post" action="https://order.store.yahoo.net/yhst-11089400041767/cgi-bin/wg-order?yhst-11089400041767+c8wz-9a589-a">Print This Page
Bookmark Page
Availability:
Usually ships the next business day
Orderable?
Part #: C8WZ-9A589-A
Price:$68.00
<input name="vwitem" value="c8wz-9a589-a" type="hidden">I Need to Order: <input name="vwquantity" value="1" maxlength="3" size="3" type="text">
<input value="Order Item (add to cart)" type="submit">
<input name=".autodone" value="http://www.cougarpartscatalog.com/c8wz-9a589-a.html" type="hidden"></form></td></tr></tbody></table>
</td></tr></tbody></table></td></tr><tr><td width="600"><map name="16b314de7e88240f8"><area shape="rect" coords="0,0,175,131" href="http://ep.yimg.com/ca/I/yhst-11089400041767_2159_29189894"></map>
Description:
Factory two barrel carburetor spacer plate. Positions carburetor above intake manifold for proper linkage operation. With PCV fitting at rear. Unique to the X code 390-2V premium fuel engines.
</td></tr><tr><td><table width="600" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td>
</td></tr></tbody></table></td></tr></tbody></table>They are normally in stock. They are 1/2 inch thick. Should work on any Autolite or Motorcraft 2V carburetor. The butterflies are the larger size on that 390 carburetor though.
Thanks guys..I have one about 3/8".
I guess I'll need to put in longer studs.
