1 - 20 of 22 Posts
I need the passenger side quarter window horizontal trim piece. I lost the original piece. The trim I am looking for is the extension of the trim on top of the door on the exterior. The extension is about 10 inches long and 3/4 inches wide and is polished alum and sits just outside the quarter window. These trim pieces are unique to the XR7 and I nee one from a convertible. I believe they are common for 71 thu 73.
john dempster
I am search of a nice day/night rear view mirror, rear ashtrays, trim around the headlight buckets, the rubber rear bumper to body shields, trim piece under the steering column, rubber shields that mount on the underside of the fenders at the top rear where they come to a point, wheel whell trim, and possible rocker trim. Incidentally these items would be for my 71XR7 Convert. Do you have a nice AM/FM radio. Thanks, Cougaral
Pro'lly a long shot, but how are the rocker panels?
73 cougar
Hello,
I am looking for the red, rectangular xr7 emblem that goes on the top of grill in the center.
Do you have one, and if so, what woudl its condition be and the cost.
I also need the stock door lock release knobs that go in the top of the doors. I am probably not using the right name but I am new at this stuff.
Could you reply to my regular email ( [email protected] ) as I do not have very much time to check the boards.
Many thanks
Fran Long
Power Window Switch
Do you have the power window switches and the box they reside in on the driver's front door? I have the bezel but I'm looking for the guts.
I have a 72 XR7 and I'm hoping they might be a match.
Your 72 PW switches should be the large rocker style. A 73 uses a smaller finger style switch. I think that you will find that the switches are the same 69-72. However the switches in the left door panel will not interchange with the 3 single switches in the other locations.
Randy Goodling
CCOA #95
1 - 20 of 22 Posts
