I finally got the timing chain replaced in the X brand car, and timed and runs real good, except it overheats after 5 minuts of running. I put in a new thermostat, back flushed the whole system, and now the upper rad hose collapses, what the F....... Its an 81 Chrysler 318, and has a new rad (1 month old), head gaskets changed when we first got it (3 months ago). It ran crappy before the chain, and all I did was replace the chain with a stock new set and now it starts and runs great. What causes the hose to collapse???
Rick
I'm not sure on that one Rick, but you could try buying one of the hoses with the spring inside, so it wont colapse.
I have seen lower hoses collapse with out a spring or wire in them because of the pump's suction, but this usually happens at highway speed (higher revs).
The only times I have seen upper hoses suck themselves flat is when there is air in the system.
Air in the system or The thermostst is/was defective... did you test it before putting it in? or a bad cap...
Don
