1 - 2 of 2 Posts
Right now my '68 has a rebuilt C4 transmission. I'd like to put an overdrive transmission in the car. Can anyone tell me the model of an overdrive transmission that would work for my car.? It has a 302 V8.
Thanks, Nate B
AOD would be the easiest. Found behind just about everything from '83-91 in SBF or 4.9 (300ci- straight six) or 3.8L V-6 form. All will bolt up to a SBF (302/351) bolt pattern. You only need to set the TVS cable or rod for proper preload. Bear in mind that the AOD has a .67 o/d ratio that makes 3.00 rear gears feel like 2.00s in o/d!
1 - 2 of 2 Posts
