1 - 8 of 8 Posts
Does anyone know for certain where the battery cut off switch was mounted on the 67-68 Trans-Am race cars? I've heard the antenae hole in the fender but have since seen this to be false. I am going for the trans_am look with my 70 cougar. But since there were no factory team cougars that I know of in 69 or 70, I am sort of making my own. But I would like the end result to have some flavor of the factory race cars.
Cool, I would love to see pix. Do you have the Boss 302 suspension build book. I just got it and holy cow, it's awesome. It gives a real good plan on Trans-Am'in the Cougar. I might be going that step on my 70. First is a few blasts down the 1/4, then road courses if it's not good enough,lol.
Rick
WELL, LET US KNOW..??
WHERE IS THE FUEL CUTOFF SWITCH LOCATED ON THE 67 TRANS AM COUGARS??:)
Discussion Starter · #5 ·
i have done almost the whole suspension on the car except rear leafs. i relocated the upper cont arms, installed new shaft kits, new ball joints, and spring perches. for the perches i used a set out of a 64 falcon, which if you didn't know, have a solid shaft qwith a greasable brass bushing pressed into the perch body. if you don't mind feeling the bumps in the road, I think this is the only way to go if you use stock type parts. I also boxed in the upper & lower cont arms by welding some 16 guage sheet steel that i cut and fit to the control arms. kind of like the first stuff from global west. for springs i used a set from a big block air cond. car. they are new, and i cut out about 2 5/8 of a coil to get the ride height where it should be. i also use a set of tall 65-66 mustang front shock mounts. this gives a little more shock travel and doesn't hit the bottom of the hood. only works on 69 & 70 cars. i have yet to weld up the seams in the eng compartment since ive only had the car 3 mos. and am planning a fresh motor this winter so ill tackle the welding while the eng comp is empty. im using 1 1/16th front sway bar with poly bushings and kyb's . for wheels i've got some 15 x 8.5 mini lites with 265/50/15 dunlops. had to trim some of fender but not too much. also has 16:1 manual steering which sometime sucks in a tight parking lot. I'll be posting a pic or 2 in the near future.
as for the fuel pump cutoff, i'm using an aftermarket manual pump.
Boxing the control arms are a good move, I used to do the same on my early dirt cars. I do not mind having to cut coils out of springs, but you do realize that you raise the rate of the springs when you do that right? 2 and 5/8 coils cut could raise the rates as much as 100 lbs maybe. mm
MM...what do you mean by cutting the coil will raise the rates?
Just curious....
Dale
Dale, it just as I said, when you cut coils out of a spring it gets stiffer. For example a 500lb spring with one coil out will increase in rate, depending on the free height and coil diameter. mm
1 - 8 of 8 Posts
