I have traced the little blue wire with the red line everywhere..ha
This is what I need help with DASH LIGHTS::::my turn signals work, emergency flashers work, headlights work, horn works and radio works all under dash lights work to include door lights. Oil light works, fuel gauge works..I've tested the voltage regulator, it is still good, I only have two wires to follow and they go under the carpet to somewhere I have not found just yet...Every time I turn the headlights on no dash lights, when I turn the dimmer to make the interior lights come on....blink there goes the fuse...I went through ten fuses today with no luck...I removed the headlight switch took it apart cleaned it out put it back in and still no luck..Any clues??????? Thanks Lance
