It seems that my oil pump shaft has become dislodged from the pump and as a result I can not install the distributor as it can not line up with the oil pump shaft. The shaft is "falling" to the side and I'm told that if properly installed into the oil pump it can not fall like that. Does that seem true?
Assuming this is true, I need to pull the oil pan, remove the oil pump, and reinstall the shaft. Is there anything tricky to this? I've never pulled an oil pan and I'd like to be prepared for whatever I may be getting into.
This is on a 289.
Thanks,
This is on a 289.
Thanks,
