I've recently swapped motors in my '67 Cougar (rod knock in the original motor). I have a circa '88 302 roller motor. I have the stock '67 oil pan.
Since I'm using the late 80's pulleys/belt/PS Pump and alternator, the front dipstick will not work.
Since I have the '67 pan on the '93 block - the side hole in the engine block for the dipstick tube is blocked by the gasket rail on the '67 pan.
Yes, I can have someone customize my pan to hopefully weld a cutout in the rear portion of the pan so I can insert a dipstick, however I'd rather not have to do that.
Does anyone know of a Windsor motor car pan or aftermarket pan that will fit in these old cougars to enable the use of the later side mounted dipsticks?
