I have two OEM Ford 600cfm Holleys from GT390s at a buddy's house for rebuilding. He wants to put them on his swap meet table, but doesn't know what they're worth. He sold my other one ('67) for $75 and I was more than slightly PO'd!!!
These are the ones with the dual-inlet center-pivot front bowls and the exterior feed line on the passenger side to the center pivot rear bowl. NOT like a 4160-style transfer tube on the driver's side. Metering blocks on both primary and secondary sides. The 428CJ used the similar setup, but was 735cfm.
I have a 66 and 69-stamped carbs. Or should I put them on eBay to get a wider market. Any idea of value????
As I am sure you know Milo, ebay will usually yield maximum price and has a wider audience by far (which leads to the former). Of course there are the myriad of fees associated with going that route. CL is another option but you have to figure out what to ask price-wise.
Holley 4150 style?
What are the numbers? C9AF-9510-U is the most common carburetor found at swapmeets.
Discussion Starter · #4 ·
My buddy was thinking about pairing it with a FE-4V intake... You know -- those 135-pound boat anchors. Why he wants to drag that heavy thing around to swap meets is beyond me, LOL!
I'll have to get the carburetor air horn numbers, but IIRC they're C6OF-AB and C9OF-? along with their List numbers and date codes.
You can call Pony to see what he would give you for a core and then base your local selling price off of that.
Pony Carbs
Some of the "common" carbs and bad date codes are not worth very much other than as parts.
Discussion Starter · #6 ·
<edit> *edit* I thought better than to say what I wanted to say about Pony... :realmad:</edit>
