1 - 2 of 2 Posts
In my other post I talked about a wiring issue i had where i burnt some stuff up. I have since put in a new mallory unilite ignition module, new msd box and coil. I still cant get spark. I have performed msd test which is disconect the green dist wire from the white trigger to the msd box. Next pull the coil wire off the dist and touch the white trigger wire to ground. I get spark so box is good. (turns out my old box wasnt bad afterall). PROBLEM is when the green and white are connected like they should be I get nothing. Could my BRAND NEW ignition module be bad?
Discussion Starter #2
update brand new mallory ignition module was bad. My old one that actually melted the wires together during the wire mixup actually worked. Now if I could get my headers to not leak and my electric fans to work
1 - 2 of 2 Posts
