I just changed out every lamp on my 1970 Cougar to a LED light. Just put the Dash back together today and hooked up the battery. Now it seems like all the interior general lights work fine. With the headlight switched pulled I am getting like half the instrument cluster lighting up one blinker indicator on the dash wont change just stays on. The Headlight doors and headlights wont even light up anymore (I did not change the Headlights). None of the blinkers work. I am assuming I need to change the turn signal flasher unit and the emergancy flasher unit to make these work properly. Doese anyone know if this will fix the problems or if I need to keep looking elsewhere before the units get here. I purchased the LED's from superbrightleds.com. I also bought the two flasher units from there. I am not very framiliar with the electrical lighting circuit in the car. Thanks
