Get under the dash and start moving the vacuum valve arms while the blower is on. You may have one that isn't working and all the vents are staying closed. The vacuum valves can leak and none of the doors will open without enough pressure. If you need to replace the vacuum parts, Classic Auto Air has them. I had a bolt that somehow jammed in my defrost vent door. So I could never get air to move to the hi low vents, it was always defrosting. Once I cleared that, everything worked fine. Just listen for any hissing while the car is running under the dash.
