New! Version 1.2 Electronic Low Fuel Indicator (ELFI) Kits. Version 1.2 brings you an even greater improvement over the previous versions of the ELFI as compared to the original thermistor sender based system. Flashing at threshold has now been completely eliminated! A time delay has been incorporated into the circuitry (in addition to the hysteresis that improved the flashing at threshold originally). This delay requires the low fuel level from the sender to be present for approximately ten seconds before the Low Fuel lamp will be illuminated. The same is true of the Low Fuel lamp extinguishing once it has been triggered. The signal from the sender must be above the low fuel level for approximately 10 seconds before the Low Fuel lamp will be extinguished.
As always, a Low Fuel sending unit is not required to work with the ELFI! Any working sender (low fuel or standard) will work, the ELFI develops the low fuel indication using the fuel level voltage level created by the sender rheostat and gauge.
With the V1.2 ELFI Kits, you can have a Low Fuel indicator on your Classic Cougar which works as well as those found on modern vehicles.
Kits are $135 shipped to the lower 48. Paypal accepted.
Also available, Solid State Instrument Voltage Regulators (SSIVR's) which are part of the ELFI kit (but available separately). They are solid state Instrument Voltage Regulator (IVR) direct replacements for the OEM Bimetallic regulators.
SSIVR's are $45 shipped to the lower 48.
ELFI's on the left, SSIVR's on the right.
Thanks,
Robert
Thanks,
Robert
