my 73 has a 2v stock cleveland. Started idling ruff out of the blue. The pertronix ignitor rep said that my low battery may be the problem. I replaced the distributor with a points (single) set. Set dwell at 30 and timing at h degrees BTDC. Now it is backfiring when I come off of the gas. What have I done wrong?
Your timing must still be off. Do you mean 6 degrees BTDC instead of h? Is the mechanical or vacuum advance working? Has the rough idle gone away? We really need more information to help.
sounds like timing is to far advanced. back it off a little and the popping should go away.
I did mean 6 degrees BTC... sorry. The popping did sound retarded alright, so I did back it off and still there was some- less, but still there.
It was a real wonder because I am taking a body/paint class on Friday and Saturdays. I drove it there on Friday... all was fine- I left it there overnight. Saturday I drive it home it popped and ran like hell. I forgot it until the next week and it was still popping. Now I have replaced the distributor, the pertronix ignitor with standard points, cap and rotor. Checked all the vacuum lines for leaks and the plugs are only100 miles old. When I pulled the plug wires to take picture to post here of the vacuum routing I was using, I realized my problem. I have 5 Chevy's in my driveway and this Cougar- the only ford. The firing order and cylinder sequence are known to me to be different- in fact I always print out a picture of the 351c firing order when I work on the distributor. But... my brain is always saying 1-3-5-7, 2-4-6-8, even though the diagram is saying 1-2-3-4, 5-6-7-8 :bloated:.
Anyway, I caught myself counting the cylinders like I was hovering over a SBC twive before I got to the last wire in the order- it was then that I knew... I don't bleed Ford Corporate Blue :eek2:.
I timed the ignition at 6 degrees BTDC, Set the dwell at 25 and it ran like the proverbial top. Thanks to all that tried to help.
ps. I sold all my chevy's the same day and bought yugos. :toung:
