1 - 10 of 10 Posts
I got my new leaf springs and poly bushings from espo installed last weekend. The front end bolts were a nightmare(arn't they all?) to remove, but nothing the oxy- acetaline torch couldn't handle. Those big rubber bushings burn and melt into tar real good. If only I could get that much smoke coming out of the wheel wells when I do a burnout:rolleyes: .
The car handels much better now, and rides more level. The really scary part was I had several broken leafs, the second biggest leaf, and the smallest leaf on the drivers side. On the passenger side the second biggest was broken also.:( The small drivers side leaf didn't really break, it disintegrated when I knocked the saddle off with my BFH.
In all, the job was rather challenging, but kind of fun. :)
rear leaf springs
It's even scarier when you get the old springs out and you find that your main leafs were broken! BTDT. :eek:
I feel your pain, my driver side support basically snapped when I did mine. Just called and ordered the front end rebuild kit from espo too.
How do you tell if the leaf springs are broken? I mean easily, not by taking them apart, which from reading the above sound like a tough job. Does the cougar have to have its own special leafs or can I just find similiar ones [length etc], I am sure most LDV's have the same size springs, but that is just by looking at them, do they have their own fittings that differ, like a towhitch, look the same but each make has its own way of fitting.
Next Question, why is there a shock attached to the leaf springs, I presume its a shock absorber, my bakkie has leaf springs but no shocks attached, in fact the leafs don't even spring but thats another story.
Without the shocks, the leafs would bounce uncontrolled. The shocks control the damper [compression] rate and rebound, as car returns to ride height.
Okay thanks, but to the first question how do you tell if one or more of the leaf springs are broken?
Leaf Springs
I got my leaf springs from ESPO. Shipping to southern Maryland was $24, not too bad. I took everyone's advice and had the shop put them in for $140. Car rides nice now. The driver's side main spring was broken on mine. You could see where it rubbed against the bracket.
Leaf springs can be all sorts of fun. The replacements I'd put on were faulty - one side literally had a warp to it. Once on the car it pushed the axle off center 7/8" toward the passenger side.
I replaced them with 4 1/2 leaf standard height springs and at the same time changed over to gas instead of air shocks - the ride height back there is just about right far as I can tell.
It's much harder to take the old ones off than put the new ones on. Just remember your WD-40, a wire wheel to grind the crap off the surrounding parts and it'll all go together quick and smooth.
1 - 10 of 10 Posts
