1 - 2 of 2 Posts
When I got my 68 standard, he PO had pulled the a/c. I want to at least have heat. Can I use the non-a/c heater box? what are my [cheapest] options at this point? thanks
Was the compleet A/C unit removed? if so then a non A/C heater box could be installed but you will have a big hole in the fire wall. If the A/C heater box is still in the car you should be able to get the heater section working. Neal.
1 - 2 of 2 Posts
