First check the differences in the mounts and change those. Next check wiring, slide in motor, make sure everything bolts up and plugs up correctly. adjust coolant system as necessary. Make sure tranny bolts up correctly. 351w4bbl should fit nicely. Follow repair/rebuild manual for 351w specs once motor is mounted correctly. Other than that it's like going to Disney World for the first time, follow signs and directions.
