This is typically an easy fix.
Yank the tach out of the cluster and disassemble it carefully. Inside you'll find where the wires connect up to the tach via soldered connections. It's right there where the solders typically crack. Just heat em up, add a bit of solder and reassemble.
Took me about 45 minutes from start to finish for mine...
