I purchased an under the hood upgrade kit to replace the componnents under the hood on my 68 XR7 302. All the original stuff was missing except for the expansion valve which is mounted under the hood right at the firewall. I have been told that I have to replace this old one with the one supplied in the kit but can not get it to move. Have been spraying the fitting with penetraing oil for last couple of days at least a few times a day, nothing. Anyone taken one of these out before? The other fitting coming from the firewall accepted the line no problem but I noted that the nut on the fitting on the car does NOT move, tighten hose to fitting and use wrench to make sure don't twist tubing coming through firewall. I am not sure if the fitting that holds the expansion valve moves or not. Expansion valve is difficult to get a good purchase on because there is no "wrench specific" point, have resorted to channel locks to try and move it. Am really stuck and cmpany that sold me kit is NO help. Please Help...
Charlie
Charlie
